1206 sprung a leak
Chad 1206
07-26-2004 20:04:57
Question for you guys out there. My 1206 started leaking oil, a good amount, out the engine oil cooler. It leaks out the front of the tube between the tube and the elbow to the water pump.
My question is, is there something I should look out for when taking this apart? Any special things to do. I am a little concerned just because the antifreeze and oil both run through there.
Any help is greatly appreciated.
Chad
