986 3pl Hydraulics
Huey
07-27-2004 03:12:24
I have a problem with hydraulics on the 3 point linkage of my 986. When I move the in-cab position lever to raise the linkage it wont stay in place. It drops right down again as soon as I take my hand off the lever. Also theres a bit of a shudder in the system when I`m letting it down. Can anyone help out? Much appreciated
Huey
07-28-2004 01:51:23
 Re: 986 3pl Hydraulics in reply to Huey, 07-27-2004 03:12:24
Allan & Bernard. Thanks for your help. Have fixed the problem.
Bernard Chénard
07-27-2004 09:48:09
Hi Huey, check at the rear end of the linkage for two 5/16 bolts that tight a slot. Thight a few those bolts to keep the lever in place. Bernard le mécano Québec Canada
Allan in NE
07-27-2004 04:26:22
Huey,
Tighten the friction clutch on the lever. They all end up doing this from time to time; normal wear and tear.
Allan
