Question for Hugh MacKay?
Joe VA
07-27-2004 09:18:36
Hugh, you posted a response to a question I had on the adjustment of the clutch release levers on a Farmall 200. Is that distance that you gave with everything bolted up to the flywheel? Thanks.
Hugh MacKay
07-27-2004 20:20:46
 Re: Question for Hugh MacKay? in reply to Joe VA, 07-27-2004 09:18:36
Joe: You may have to jog my memory a bit, I remember this and found the figure I gave in the IT service manual. I may be just tired, but I just cant seem to find it again to quote the figure. I would assume that figure is for new parts bolted up to flywheel.
Joe VA
07-28-2004 06:01:43
 Re: Re: Question for Hugh MacKay? in reply to Hugh MacKay, 07-27-2004 20:20:46
Thank you, that's what I needed Hugh! Have a good day.
