Farmall m pto ??????
Mike V.
07-27-2004 10:51:14
Hi, I have a Farmall M tractor. The pto shaft was leaking, so I disassembled it and now I'm having a hard time finding the main seal assembly. Can anyone help???
gorilla
07-27-2004 18:47:58
 Re: Farmall m pto ?????? in reply to Mike V., 07-27-2004 10:51:14
Be careful putting that housing back on. I cracked mine & had to go to the salvage yard & pick up another one. Run the bolts down by hand & then tighten each one a little at a time.
CNKS
07-27-2004 18:14:29
Case-IH or any bearing place can get that seal.
Mark
07-27-2004 11:28:20
Depends on the S/N. Mine is a '44 and I got IH p/n 358812R91. It is different from the orignal seal and some guys double em up.
Mike V.
07-28-2004 11:21:25
 Re: Re: Farmall m pto ?????? in reply to Mark, 07-27-2004 11:28:20
Thanks everybody for your quick response. I will contact my local IH/case dealer, but not sure why serial number is, there is alot of numbers stamped all over the tractor, which one do I use, or where do I look to find the right number??? Mike
Jed
07-29-2004 10:46:37
 Re: Re: Re: Farmall m pto ?????? in reply to Mike V., 07-28-2004 11:21:25
Call joe's farmall at 814-226-6214
