Farmall Red, which color?
phillip
07-27-2004 14:42:57
I am restoring a 52 Farmall Cub. What is the correct color? Paint code? Is a 46 Farmall H the same color? I bought some paint last year, but I think it is IH red and not Farmall red, it is too light in color. Thank you
CNKS
07-27-2004 18:02:27
 Re: Farmall Red, which color? in reply to phillip, 07-27-2004 14:42:57
IH 2150 is correct for your Cub. Your H was painted with IH 50, no longer available in pre-mixed colors, at least not from Case-IH. The PPG code for IH 50 is 70019, Dupont, 7410. The PPG code for IH 2150 is 71310, DuPont 96766. IH paint did not differ in color for Farmalls Internationals, McCormick, etc.
Josh
07-28-2004 05:48:40
 Re: Re: Farmall Red, which color? in reply to CNKS, 07-27-2004 18:02:27
CNKS. Would a 53 Super C be the same color as the cub or the H? If it is neither what would the PPG code be for that?
CNKS
07-28-2004 18:39:39
 Re: Re: Re: Farmall Red, which color? in reply to Josh, 07-28-2004 05:48:40
There are two colors of red available, IH 50 for tractors built until sometime in 1949, IH 2150 thereafter. There was another shade, 1102b, used from 1949 until the late 50's, when 2150 came out, that paint is no longer available, and far as I know no cross references exist, so use 2150 or equivalent.
Eric
07-27-2004 16:27:13
use 2150 red
rustyfarmall
07-27-2004 16:55:49
 Re: Re: Farmall Red, which color? in reply to Eric, 07-27-2004 16:27:13
2150 is available from any Case-IH dealer, the H and the cub should be the same color.
