986 power steering box
Huey
07-28-2004 02:05:00
I have an annoying oil leak in the power steering box of my 986. I have replaced the rubber seal which is cylindrical in shape about 3 inches in diameter and about 2 inches deep and tightened the bolts well( theres about 8 of them )and oil is still leaking from the second join from bottom although not as bad as it was.Has anybody any remedies?
RPM
07-28-2004 07:52:57
 Re: 986 power steering box in reply to Huey, 07-28-2004 02:05:00
Its actually called the power steering hand pump, when you get the replacement rubber sleeve it should be 1/8" longer than the steel sleeve to allow for crush seal.
Huey
07-29-2004 02:58:18
 Re: Re: 986 power steering box in reply to RPM, 07-28-2004 07:52:57
RPM. The rubber sleeve I installed was new and probably only 1/16" longer than the steel sleeve. For some strange reason its inadequate.
