FARMALL A CARB TROUBLE?
DON C
07-28-2004 12:15:35
ENGINE AS A SMALL MISS, WHEN I ADJUST SCREW IN OR OUT IT DOES NOT EFFECT ENGINE OPERATION AT ALL ,NEW POINTS , NEW PLUGS AND WIRES , HEAD REBUILT ,VALVES ADJUSTED CORRECTLY ,I REBUILD THE CARB BUT DID NOT MAKE ANY DIFFRENCE THANK YOU FOR ANY ADVIVE YOU CAN FORWARD
Jeff In Ontario
07-28-2004 16:13:33
 Re: FARMALL A CARB TROUBLE? in reply to DON C, 07-28-2004 12:15:35
2 things come to mind here: #1 - The carb needs to be cleaned out/all the jets & passages blown out with a compressor or #2 - The valves need to be adjusted & set. Hope some of this helps! ---Jeff
