H cylinder sleeves
Dale L
07-28-2004 18:27:10
I'm putting in sleeves in my H engine tomorrow There in the freezer over nite tonight. The manual says to lube the block with a lite oil. Can any one recommend what kind of oil to use?
Thanks
Wayne Swenson
07-28-2004 18:46:00
 Re: H cylinder sleeves in reply to Dale L, 07-28-2004 18:27:10
Try some WD-40 or JB-80. It doesn't take much lubrication.
Be sure the cylinder bore is clean in the block and the groove for the sleeve lip is also clean.
Have a block of hardwood and a hammer ready so you can tap the sleeve into place quickly. The lip must be flush with the block surface (or very close to flush) so the head gasket sealing ability is not compromised. Try a new sleeve upside down in the groove to see if all is ready before installation.
The sleeves are brittle so be careful!!
