IH Model 314 3 Bottom Spinner Plow
Ricardo
07-28-2004 20:04:38
Does anyone know where I can buy a chain for this plow. The chain links say C-2080 Morse on them.
Allan in NE
07-29-2004 04:33:33
 Re: IH Model 314 3 Bottom Spinner Plow in reply to Ricardo, 07-28-2004 20:04:38
Ric,
Do you have the ends of that chain?
Because if you do, that is just a standard chain, which is available from any implement dealer. If not, I think you could construct the attaching points out of 5/8” threaded stock.
Those are one sweet little plow, is yours set up with the 3 point update?
Allan
ricardo
07-29-2004 19:20:34
 Re: Re: IH Model 314 3 Bottom Spinner Plow in reply to Allan in NE, 07-29-2004 04:33:33
I just bought it and and trying to get it working.What is a 3 point update. I hook op to it with a JD 4440 but the chain is broken. The cylinder is leaking in three places, so I will probably have to fix it also.
hagan
07-29-2004 20:00:41
 Re: Re: IH Model 314 3 Bottom Spinner Plow in reply to ricardo, 07-29-2004 19:20:34
you have way too much tractor for that plow!! Be careful. If you want to load that tractor you need a IHC 140 4 bottom spinner. They are reasonably priced anymore. By the way do you have the chiefs or the old GAU bottoms? Good luck and don't pull the ears back on that 4440 or you will have scrap iron
