super M compression......whats acceptable
steve
07-29-2004 05:25:48
planning a rebuild on my super M, and I did a compression test last night. 92,109,120,115. other than the 92, those numbers dont look bad to me.any thoughts?
Chad from MI
07-29-2004 06:30:18
 Re: super M compression......whats acceptable in reply to steve, 07-29-2004 05:25:48
Did you have the throtal all the way to full when you did the test?
If you did now take and put a squirt of oil in the one that was 92 if it goes up you have bad rings if it stays the same or close you need to adjust your valves. Myself I do not think I would rebuild it with those numbers. If it runs good leave it.
Chad
