560 Engine Oil
Hal W
07-29-2004 17:50:42
Greetings,
I am going to change the oil in my 560 (first time). The manual says to use a 30W oil. Simple, right?
Well, a friend of mine says to be sure to use a 30W *diesel* engine oil. And I see TSC has diesel engine oil. Another buddy (who has several diesel tractors) says he just uses 30W car motor oil.
So...do I really need the diesel oil?
Is the TSC brand (Traveller) good or would you folks recommend a name brand oil? If the latter, which one?
Thanks for the advice.
Hugh MacKay
07-29-2004 19:14:41
 Re: 560 Engine Oil in reply to Hal W, 07-29-2004 17:50:42
Hal: Definately go with the diesel type motor oil, whether you go 30W or 15W-40.
35 years ago I was running 9 tractors, 4 trucks, a car and an assortment of small engines. I was using 3 kinds of oil, and having employees, the proper oil did not always go where it should. Simple fix was use one kind of oil. I went with diesel type and back then 30W in summer and 20 in winter. Since that time I have switched to 15W-40. I have used both oils in every vehicle from a 560D, 1066, Super A, Chevy pickup both gas and diesel, Buick and even my 4 cycle lawn mower. The lawn mower has always mowed a 1/4 to 1/2 acre. It was given to me by then IH dealer in 1975 when I purchased the 1066. The engine is original. In all those years I've never experiences premature failure of an engine. Couple didn't last as long as I thought they should, but I wouldn't call it premature failure.
Boyd
07-29-2004 18:44:17
Hal W, I use TSC 15-40 in my SM, 2Ms and my H. They all work in the field. I have had no problems with any of them. This is a Diesel oil. They all hold good oil pressure. Boyd
