Need Info-404 Utility
TDK
07-29-2004 23:19:25
Looking for advice on weak points,etc. of an IH 404 Utility. Tractor has new rear tires and good fronts. Overhaul in '99, new clutch,etc. in '02. Needs rt. side hood, left front side panel(behind grille), brakes , steering u-joints & paint. Tractor has 8 speed trans. A shifter on left side of trans. housing operates it. Are these reliable? Thanks for any info!!!
Jeff
07-30-2004 12:16:07
 Re: Need Info-404 Utility in reply to TDK, 07-29-2004 23:19:25
TDK...
Sounds like you have a 404 U with a two speed transmission. These are not common but rweally adsd to the operational workings of the tractor. Could be a hi-lo or fast reverser depending on if it has the reverse idler in the case. Either way... that 2 speed is worth $8-900.00 by itself. 404 was a good little tractor. I have 1 utility and 2 row crops and LOTS of good parts for sale.
Marv
07-30-2004 07:47:06
I'm currently trying to get a 404 utility running. The motor (a rebuild) is probably the only thing that is good on it. Tin is rough and hard to find. The steering and clutch needs to be rebuilt. I just replaced the hydrolic pump. The list go on.
