466 coolant filter advise
Todd_PA
07-30-2004 19:39:57
I purchased a 1982 S1900 truck a year ago with the DT466, that just had a new short block put in prior and it doesen't have the coolant filter conditioner assembly. I changed the coolant last fall with 60/40 glycol antifreeze and water. I just purchased two pints of Fleetguard DCA4 conditioner and added it to the system, per the recommended chart to get the recommended levels of molybdate and Nitrites. Per the test strips, if the readings are really low (below 1.2 units per gallon) it says to change the coolant filter and add a pint of DCA4 and if the readings are between 1.2 and 3 to either change the filter or add 1 pint DCA4, and above 3 not to do either. It says to check at every oil change interval. I can purchase a used coolant filter assembly from a DT414 and install but would like to know if others feel that is a benefit over just adding the DCA4? I didn't know if the conditioner filter just adds a time dose of conditioner or actually is needed to filter the coolant? I want the engine to last a long time. Any advise is very much appreciated.
Thanks, Todd
Bermuda Ken
07-30-2004 20:39:04
 Re: 466 coolant filter advise in reply to Todd_PA, 07-30-2004 19:39:57
Install the filter kit. This is much more fool proof to operate. You need to change the filter at regular intervals,(just like the coolant itself).
Many coolant filters have a rubber sealing plug in the threaded hole. REMOVE the plug before installing or it won't work and will leak.
Take oil samples at every change and have them tested too.
Todd_PA
08-04-2004 19:25:41
 Re: 466 coolant filter advise in reply to Bermuda Ken, 07-30-2004 20:39:04
Thanks Ken, I purchased an assembly and tubes from a 1086 for $63 and will install once I replace the little rubber washers at some of the connections.
Todd
