Spark plugs for WD-6
Con
07-31-2004 06:38:29
Are the spark plugs for a WD-6 the same as for a W-6 or M? Or do they use a different plug? Thanks in advance for help in clearing that up for me!
Nebraska Cowman
07-31-2004 10:23:28
 Re: Spark plugs for WD-6 in reply to Con, 07-31-2004 06:38:29
I've got some old new stock W-89D for a discount if you are interested. They have some rust flecks on them. $20 a set of four.
Nebraska Cowman
07-31-2004 16:46:43
 Re: Spark plugs for WD-6 in reply to Nebraska Cowman, 07-31-2004 10:23:28
oops that won't work you need D-89D
Smitholm
07-31-2004 07:51:18
Champion number was D89D, now 543, I think. I've gotten them through NAPA - be prepared to spend $7 or so a pop. Good luck.
David Manring
07-31-2004 06:55:10
Con, they are different than a regular gas only motor.They look like the ignitor plug on a space heater or what some call a salamander heater.The porcelin or outside is similar,but has a long electrode
