Hand Cranking After Rebuild.............
jmh
07-31-2004 14:22:13
After a complete rebuild is it usually difficult to hand crank a tractor? This is a B Farmall with Magneto. I installed a starter and it starts right up, but it just won't start with the crank. Mag seems to be working fine. Engine runs great, idles down good, etc. Do I need to loosen up the engine by running it for a while? Thanks.....
lee
07-31-2004 21:02:20
 Re: Hand Cranking After Rebuild............. in reply to jmh, 07-31-2004 14:22:13
True, it may be a little tight for a while.
Nebraska Cowman
07-31-2004 16:48:26
sometimes they are a little tight.
Eric
07-31-2004 18:33:17
 Re: Hand Cranking After Rebuild............. in reply to Nebraska Cowman, 07-31-2004 16:48:26
My F-20 was the same way just letting the motor breake its self in will loosen things up and easyer to crank by hand
Eric
