Tapping Tie Rod End
Country Lad
07-31-2004 14:57:51
I had to replace the tie rod ends on my 986. The new ones were fitted with a grease fitting in the sheetmetal cap. i was wondering if the life would have been extended had I drilled and tapped the old ones before they were worn out. Anybody ever do this? If you have where would you drill them?
K.B.-826
07-31-2004 20:05:36
 Re: Tapping Tie Rod End in reply to Country Lad, 07-31-2004 14:57:51
It seems to me that your old tie rod ends should have had grease fittings. Look them over closely, did they get knocked off or somthing, could the hole they were in be hidden by dirt?
