Order Farmall Cub Parts Online
Touch Control on Cub Loboy
EZ
08-01-2004 05:50:53
Guys,
I'm doing a Touch Control rebuild on my '67 Cub Loboy. Things are going very well so far, this is my second one, so I know my way around abit. Problem is, I cannot seem to remove the 3/4
Dieselrider
08-01-2004 06:49:51
 Re: Touch Control on Cub Loboy in reply to EZ, 08-01-2004 05:50:53
Wish we could see the rest of your post.
EZ
08-01-2004 07:07:51
 Re: Touch Control on Cub Loboy in reply to Dieselrider, 08-01-2004 06:49:51
Me too!
I'm not sure what happened to the rest of it, but it looks like both times it stopped after the characters for
EZ
08-01-2004 07:09:48
 Re: Touch Control on Cub Loboy in reply to EZ, 08-01-2004 07:07:51
This is crazy. I do not like the reserved names format! All I do is type in 3/4" and my post stops.
EZ
08-01-2004 05:56:46
Not sure what happened, but only a small part of my post was actually posted.
I cannot get the 3/4
john *.?-!.* cub owner
08-01-2004 11:55:39
 Re: Touch Control on Cub Loboy in reply to EZ, 08-01-2004 05:56:46
Had the same problem making a post just now. Assuming you are referring to the nut on the load piston, try using a couple boards to clamp the shaft in a vice and gently applying an impact wrench.
