Order Farmall Cub Parts Online
184 Cub Lo Boy
RayB
08-01-2004 16:32:44
I need advice on the electric clutch removal from the PTO shaft. The bearing next to the clutch needs replacing, and I can not see the end of the shaft well enough to tell if the clutch is screwed onto the shaft or not. It appears to have spanner wrench holes on the clutch.
Scott BFH Harris
08-02-2004 02:36:48
 Re: 184 Cub Lo Boy in reply to RayB, 08-01-2004 16:32:44
Ray B,
Are you saying the bearing that is around the main drive shaft needs replaced? If so it is easy to remove. Let me know and I'll e mail you the procedure.
