340 charging question
yooper
08-01-2004 16:52:20
I recently put a rebuilt generator on my 340, but now the amp guage shows discharge with the tractor running, and charge with it off and the lights on. only thing I disconnected was the generator.I don't know if it was discharging before or do I just need to swap the wires for the guage??
Catskill Pete
08-01-2004 21:59:59
 Re: 340 charging question in reply to yooper, 08-01-2004 16:52:20
The fact that it shows charge with the engine off and the lights on sounds like reversed wires on the ammeter.
Mark K.
08-01-2004 21:41:24
Hello,
I would check the battery with a voltmeter and notice the polarity of the battery and meter. - on battery to com or black on voltmeter. If it is a 6 volt system it should be around 7 volts some of the other folks would know closer and 12 volt system should be 14.5 volt. Also what is the voltage with the engine off? I would think with it showing charge with engine off and lights on something is wrong.. Best of luck in the troubleshooting. Mark
