need help with artsway mower
RLS ia
08-01-2004 17:51:19
We have an 60" belly mower that came off a Cub, now mounting it on a C Farmall.Where can we get the correct bracket with the belt guide pulleys (the ones between the deck and the belt pulley drive) or a picture of one?
Thank you
RLS ia
08-02-2004 15:01:52
 Re: need help with artsway mower in reply to RLS ia, 08-01-2004 17:51:19
I forgot about the Cub PTO being different. I will contact Artsway and go from there. Thank You, RLS
TimV
08-02-2004 06:34:07
RLS: Another thing to consider is that the Cub's PTO runs at full engine speed (approx. 1800 rpm at full throttle) whereas the C's is a 540 RPM setup. You'll have to get a larger pulley to make the mower run at the same RPM as it did on the Cub, plus figuring out a way to reverse the direction.
rustyfarmall
08-02-2004 04:48:17
You may want to do some research before doing this, seems like I have heard the the PTO turns in the opposite direction on a Farmall cub, which would spin the blades in the wrong direction if mounted on the C. I am not sure of this, but you may want to check it out before going to all the work and then find out it doesn't work.
MN Scott
08-01-2004 20:17:17
You can try the artsway website or call the company directly. All so there website has a dealer locator on it. A local dealer may be able to help you.
