Are points my problem?
Jeff
08-02-2004 16:53:46
I have two magnetos. One makes a tractor run like a top. The other the tractor won't hardly run at all. On the bad one, I put new points on and the tractor ran fine for a while. I ended up switching the magnetos around a couple of times to troubleshoot different things and now the bad one will barely run at all. the other day, the tractor would not start at all. I cleaned the small part of the points really well and the breaker as good as i could get it without taking it out. tractor finally started and ran on all cylinders but rough. then it died after 5 min or so. i know its timed right and i know the firing order is right and i know the cap and wires are good cause they work fine with the good mag i have. gapped at .013 or as close to that as i could get. these points are not that old. maybe 10 hours on them at best. did i just get a bad set of points or did i do something to make them go bad faster? what else could it be? Thanks for the help.
Jeff
Mag Man
08-03-2004 04:52:57
 Re: Are points my problem? in reply to Jeff, 08-02-2004 16:53:46
Hi Jeff where are you from ? Are you sure its the mag and not a fuel problem. I have parts and rebuilt units H4 mags that is. I also take trades on rebuilt units. Let me know if you need more help. JON
Wayne Swenson
08-02-2004 19:12:44
You may have to get the magnets re-charged. Any competent shop should be able to assist you. Best bet is to send the complete unit to a rebuilder such as Lightning Magneto in Ottertail, MN. Mitch is a whizz on the older units.
john *.?-!.* cub owner
08-02-2004 16:59:53
Did you also change the condenser? A bad condenser will cause the points to burn, and also cause a weak spark. A magneto coil beginning to break down will also cause a weak spark. The spark should be a good blue color, if it's weak or yellow the coil may be going bad. If this is a work rather than a show tractor, it's easy to convert to a battery ignition coil and still let the mag operate the points nad rotor.
