Super M ?
Digger
08-03-2004 08:21:37
I just bought a Super M this past weekend. At least the back is a Super M. The drive shaft houseing has been changed becasuse the s# is for 39 M. Was woundering what are the casting numbers for a Super M engine? To make sure that this is truely a Super M motor not an M with a Super M rearend. Or any other trates to make sure this a Super M. Thanks, Dig
Novel Idea Guy
08-04-2004 11:56:41
 Re: Super M ? in reply to Digger, 08-03-2004 08:21:37
The brakes and the 264 engine are the only real telltale signs that it's a Stage I Super M. The Stage II has live hydraulics and a battery under the seat.
My money is that you got suckered, and ended up with a '39 M with Lambert brakes. :( Still, depending on what you paid, it not a bad thing.
Wardner
08-03-2004 13:24:12
If you are under the illusion that you have a SM transaxel because of the disc brakes, you need to understand that those brakes were available from Lambert and could be retrofitted back to '39 in either H or M. The Lamberts only have three bolts vs five for SM and SH.
Bob M
08-03-2004 09:04:25
Dig - A Super M engine will have the characters "C-264" cast prominently on upper right side of the block near the oil filter can. Or find the casting date code on the block. For a Super M the last character should be an X or Y (indicating 1952 or 1953)
