I 544 D
544 owner
08-04-2004 15:27:11
I need help finding info on I 544 D
Serial Number L2978S.
Hugh MacKay
08-04-2004 19:32:49
 Re: I 544 D in reply to 544 owner, 08-04-2004 15:27:11
544 owner: Are you sure the number L2978S is the serial number? I've just checked both International and Farmall models and the serial numbers start at 10250 and 10253 respectively. Is there a chance that L may be a 1? Just a thought.
544 owner
08-05-2004 06:55:19
 I544 d serial number in reply to Hugh MacKay, 08-04-2004 19:32:49
It sure looks like a "L" to me but if it is a "1" what year would it be?
Hugh MacKay
08-05-2004 19:24:29
 Re: I544 d serial number in reply to 544 owner, 08-05-2004 06:55:19
544 owner: If that L were a 1 your tractor would be a 69. If you go to left of screen under Reasearch & Info., click on serial numbers, then click on International, then click on I544 and I2544. You can do the same with any tractor. One item you have to watch with IH is listings for International, Farmall, Farmall and International. Depends on the model, so if not found in one section, then go to the other.
