H carb problem
Gary Hunter
08-06-2004 11:11:30
I have a 1951 H i've rebuilt the engine ,the carb and also took the carb back apart to check float level,blow out jets again but it will only runs with the choke almost completly closed need help please thanks in advance for the help.
Bob Frey
08-06-2004 14:09:42
 Re: H carb problem in reply to Gary Hunter, 08-06-2004 11:11:30
Take a few minutes to check the valves. I had a problem like that on a Super M and when I finally adjusted the valves properly, most of the problems went away. Hope this helps.
Bob
Charlie
08-06-2004 13:57:52
If you're getting fuel then check your manifold for leaks. Make sure its on tight, the carb is bolted on tight and it hasn't rusted through somewhere.
lee
08-06-2004 12:11:51
Not sure how you cleaned your carb but you've got to strip it bare, remove all the jets and plugs and soak it in a good chemical carb cleaner over nite to loosen all the deposits and blow it out thoroughly with compressed air. Last one I did for a guy took 2 repetitions to clean up. Cleaning in gasoline or diesel won't cut the varnish. Make sure you have good fuel flow as others have said.
Farmall Ed
08-06-2004 11:28:39
Gary, check for any fuel flow restriction between the tank and carb.Also check the small fuel screen at the point fuel enters the carb.Hope this helps, Ed
captaink
08-06-2004 11:24:25
Check the fuel flow to the carburetor. It may be barley adequate. Common trouble spot is the valve in the tank getting flies or other crud into the holes the fuel flows through.
