756 inter tractor
garry
08-06-2004 19:39:02
transhydro fluid leaking into clutch , have replace seal on throw out bearing reatainer works for a bitt and leaks again after a wile. all bearings seems to be ok. is there a better seal and or am i missing somthing
the tractor vet
08-07-2004 10:53:22
 Re: 756 inter tractor in reply to garry, 08-06-2004 19:39:02
If you replaced the seals and it is leaking again then the PTO bearing is the problem even though you think it is good replace it and the seals again and becareful when instaling the two seals , i use a seal installer on both seals as you can damage them buy just driving them in with a hammer or a punch and it is a lot of work to replace them twice.
