cutting out 154
kevin
08-07-2004 10:41:51
I have a cub lowboy 154 that cuts out under load. when it cuts out if I kickout the mowerdeck it will run fine but as soon as I put it under load it will start to cutout again. I have put everything new in it. Points plugs,wires coil and cleaned the whole fuel system and it didnt help a bit. I am baffled. Can anyone help please.
JT
08-07-2004 13:38:43
 Re: cutting out 154 in reply to kevin, 08-07-2004 10:41:51
You need to give the carb more fuel, it is still running lean.
