Farmall A Pouring water
Matt
08-07-2004 11:59:39
Hi, I fanally think I have the carb fixed, but I ran my Farmall A today, and aters and antifreeze was pouring out of the front of the tractor, not sure where from though. It was definatly in front of the engine, leaking radiator?
Phlogiston
08-07-2004 16:34:29
 Re: Farmall A Pouring water in reply to Matt, 08-07-2004 11:59:39
Farmall A's have thermosyphon cooling systems. If you have it over filled it will get rid of the extra until it finds its own level. Read your owners manual, it will explain in there. If you don't have one, get one.
Phlogiston
farmallsc
08-07-2004 12:48:04
umm, id look at all the hose and make sure taht its not cracked on the bottom, that would be my first thought. but yes other then that i would think its the radiator
Matt
08-07-2004 15:07:39
 Re: Farmall A Pouring water in reply to farmallsc, 08-07-2004 12:48:04
I started it up again, but it doesn't seem to be throwing water out, just because I wanted to see where it was coming from. But now there's just a little bit of a drip under the engine, right at the front. Maybe it's just from last time, but I'll have to look again.
