? for super c owners
wh
08-07-2004 17:21:39
just got a 52 super c. in reading guy fays book on the letter series farmall he mentions that the gas tanks were raised on the super c's from the plain c series. i know that the person i got it from had changed gas tanks. ? is can someone tell me how far above the hyd system did the super series tanks set.
wh
08-07-2004 19:08:39
 Re: ? for super c owners in reply to wh, 08-07-2004 17:21:39
thanks - thats is what i had decided. will fab some brackets that will bolt on and raise the tank.
CNKS
08-07-2004 17:29:39
Don't know the exact height, probably 1.5-2 inches, I don't have one I can measure. The C gas tank has very little clearance above the hydraulic reservoir. The Super A1 and the Super C have the C123 engine instead of the C113, and also have water pumps and taller radiators -- Thus the grille is taller to accomodate the radiator, and the hood and gas tank were raised to line up with the grille.
David B
08-07-2004 17:28:07
Guy Fay's book says that the Super C radiator was 1 1/2" taller than a C. I think that's about the distance between the tank and hydraulics. Changing the gas tank wouldn't have done anything b/c I believe they are the same tank.
haas
08-07-2004 17:57:12
 Re: ? for super c owners in reply to David B, 08-07-2004 17:28:07
Yex, same tank, but the brackets which are welded to the tank are longer so the tank sits up higher. So if you consider the brackets part of the tank, not the same.
