Almost finished with the A,,,, M tranny question
Jim in michigan
08-07-2004 20:12:47
A feller brought me his A to work on, he wanted a tune up and all the fluids changed,, well the tractor smoked,, so now I am doing rings and bearings as well as the tune up,, he will have a like new tractor when its done. Now all I have to do is get working on the M that is here with the tranny stuck between gears, any ideas on getting it out of the two gears without pulling the platform off the tractor???
Jim Becker
08-08-2004 08:04:31
 Re: Almost finished with the A,,,, M tranny questi in reply to Jim in michigan, 08-07-2004 20:12:47
About everything you need to know about fixing the M transmission problem is discussed in the "frozen gears" thread, about 1 page down the list from this thread.
In this particular case, EZ's fix is probably the right one.
MN Scott
08-07-2004 20:30:06
Pound out the pin that holds the shifter in and remove the shifter. You should be able to take a punch and line up the notches in the shifter rails. Then build up the tip of the shifter with weld and reshape it so it fits down in the rails further to prevent the problem from reoccuring.
Jim in michigan
08-07-2004 20:34:02
 Re: Almost finished with the A,,,, M tranny questi in reply to MN Scott, 08-07-2004 20:30:06
The guy who owns it wont believe that the shifter is worn, he knows it gets stuck between gears but yet refuses to see it is worn,,I am supposed to fix the tractor for him, but how do you fix something when the owner wont believe what is wrong,,I even offered to sell him the parts cheap,,I have a M for parts here and have all the parts needed,,Dunno what to do,,Jim
EZ
08-08-2004 05:11:32
 Re: Almost finished with the A,,,, M tranny questi in reply to Jim in michigan, 08-07-2004 20:34:02
I'd tell him to come and get it.
