float dont float
Keith S
08-08-2004 04:01:40
I need a carb float for a farmall 1937 f12 can someone help me.
james williams
08-08-2004 18:05:04
 Re: float dont float in reply to Keith S, 08-08-2004 04:01:40
Gordon Rice now has new floats,I just bought one 814-226-9200
John M
08-09-2004 16:57:16
 Re: float dont float in reply to james williams, 08-08-2004 18:05:04
Thank you very much for sharing the info.I desperatly need one myself!
Keith S
08-09-2004 13:27:29
Thank You James I will give him a call. Keith S
John M
08-08-2004 06:22:33
The one from a H will work!I found I had to bend mine alot and it was kinda tricky to get it just right.Im still a little sallow in the bowl,but Im waitng to fix it until I get ready for the complete restoration.Good luck finding a good used one,I have bought 4 carbs over the last two years and have yet to find a good one.
pg
08-08-2004 04:42:27
they dont make one for an f12, can use one from a farmall h. bend the rod a little and works great. pg
ffolkes
08-08-2004 04:06:42
 Did you try your Case dealer? in reply to Keith S, 08-08-2004 04:01:40
I don't know about anything other than my BN, but I'd imagine Case could help you with that. Did you ask your local Case dealer if they could order it?
ffolkes
