C engine
AZ Jack
08-08-2004 09:58:11
CNKS Mentioned in a previous post that the Super C engine had a water pump. Was the C thermosyphon? I have a 1948 C according to all data-casting codes and serial #, and it does have a water pump. Maybe engine changed out? The tank does set down on top of the hydraulic system but seems to line up with radiator etc. Thanks, Jack
Milan
08-08-2004 11:54:18
 Re: C engine in reply to AZ Jack, 08-08-2004 09:58:11
The C's are thermosyphon from the factory, but you could take it to the dealer after the Super C's came out and have a water pump installed. Hope this helps..
AZ Jack
08-08-2004 13:01:37
 Re: C engine in reply to Milan, 08-08-2004 11:54:18
Did a little grease scaling and found the date code. 'tis a C engine!! Dogone-I was hoping for a SC upgrade. Thanks for the help Milan. Jack
Milan
08-09-2004 15:09:21
 Re: C engine in reply to AZ Jack, 08-08-2004 13:01:37
I think you can get a re-power kit to get the same or better out-put as a Super C.
I would have the crankshaft inspected for soundness before doing any power upgrade.
A slim possiblity is that it may have already been done.
