806 / 706 interchange.
Coloken
08-08-2004 12:45:38
Friend knows where there is a nice 806 cheap. Problem is that it has no 3 point. Guess from Factory that way. He has a 706 thats been there and back. Will the 706 3 point stuff fit the 806? Are the transmissions the same? It it does, he may part out the 706.
RPM
08-10-2004 07:59:43
 Re: 806 / 706 interchange. in reply to Coloken, 08-08-2004 12:45:38
Hyd draft control, hitch & linkage all the same for Cat II 3 point on these, however if you swap entire rear frame a 706 has narrower bull gears than a 806.
Harold H
08-08-2004 16:00:57
The 706 and 806 rear ends are basicly the same. All of the three point and draft control parts from the 706 should fit the 806, but you will have lots of swapping to do.
Harold H
Coloken
08-08-2004 18:23:55
 Re: 806 / 706 interchange. in reply to Harold H, 08-08-2004 16:00:57
Thanks Harold, Main thing was worried about is the big lift assembly that set on the rear end. Its just a though he has. Nice running 806 at $1000.00. Hate to pass it up.
