U9 Power Unit
Dale Kite
08-09-2004 18:41:28
Just found a u9 power unit and was wandering what is the H.P. and how much to rebuild if it needs it? What would it be worth? Thanks.
Lee N.
02-27-2005 21:35:58
 Re: U9 Power Unit in reply to Dale Kite, 08-09-2004 18:41:28
Where abouts do you live? How did you come about finding this engine? Any idea if there would be any more? I'm a young fellow collecting power units. I have a U1,2,4,6, and a UD24, but I'm always looking for more. Please help if you can!
Frank Johnson
01-10-2006 16:10:46
 Re: U9 Power Unit in reply to Lee N., 02-27-2005 21:35:58
Hey Lee, I was just looking at old talk on yesterday tractor and saw where you were collecting International power unit's. I have a U9 gas power unit that runs fine, I'm asking $900.00 for it and I live in Eustis, Florida. That is about 60 miles north of Orlando. This unit was being used to pump an 18" well and push a 6" water cannon for a hay field.
Frank Johnson
JerePa
08-09-2004 19:59:13
They are in the range of 55 HP. It is the same engine as a W9 tractor. Depends on what it would need for a rebuild. Restored it might go for $500 to $1000. Depends on what someone would want to pay.
Harold H
08-09-2004 19:25:56
Don't know rebuild cost but here are some specs for you. Same basic engine as W-9 engine. As power unit: 334.5 cu in, 4.4" x 5.5", 55 rated hp at 1500 rpm, 227 torque at 1000 rpm, 5.40 compression ratio, weight 1760 lbs less skids or legs.
Harold H
