Farmall H head bolt torque sequence
SCOTT IN MO
08-10-2004 15:45:02
Getting ready to put the head on my H and was wanting to know what the torque sequence is for the bolts . I know that the head torques at 70 foot pounds. and also is it necessary to seal the studs that go through in the block.Thanks for any help. also is there any need to spray the head gasket with a sealer,thanks again.
riverbend
08-10-2004 17:45:53
 Re: Farmall H head bolt torque sequence in reply to SCOTT IN MO, 08-10-2004 15:45:02
Start in the middle and spiral out towards the ends. Follow the torque sequence that Jon gave. Re-torque after the engine comes up to operating temperature and cools off. I did not use a sealer and have a tiny oil leak under the spark plugs. When it is due for a valve adjustment, I'll re-re-torque the head, it will be fine.
Greg
Mag Man
08-10-2004 17:25:30
#1 The torque I start out at about 35 FPs My self then go to 55 then 65 to 70 I think there is a sequence in the book but I just stager them. You dont need to seal the bolts. Some say to use no sealer I my self use Spray gasket adheasive I buy from Napa. JON
