Farmall H Problem
J.C
08-11-2004 18:12:32
I got a farmall h that runs on only three. I started her up the other day and she won't run but on only three. I checked the spark it was good. I changed sparkplugs three diff times. nothin. any help would be great.
Michael Soldan
08-12-2004 15:25:33
 Re: Farmall H Problem in reply to J.C, 08-11-2004 18:12:32
J.C. how did you check the spark? If you held the wire off the plug you can get a good blue flash but that doesn't mean the plug will fire properly. My H was running on three this spring and I put new D21 Champions in and it has been fine ever since. As was suggested , check the distributor cap, check the wire for resistance then you need to dig deeper if this hasn't helped...ie) valve adjustment, stuck valve, manifold intake leak etc..... .Mike in Exeter Ontario
Farmall Ed
08-12-2004 06:00:23
JC, I had the same problem on my H recently,tried several things finally put on a new distributor cap and it runs fine now. ED
Wayne Swenson
08-11-2004 21:26:42
Check the intake manifold gasket for leaks. Run the engine & spray brake cleaner, carb cleaner or such on the manifold to engine connections. If it hits on all 4 then you have a manifold or gasket problem.
Do you have compression on the cylinder that isn't firing? Run a compression test on all cylinders to compare.
Is a valve rocker arm broken? or misadjusted??
There are several possibilities so start eliminating them one at a time.
Good luck.
john *.?-!.* cub owner
08-11-2004 18:46:27
Stuck valve?
Allan in NE
08-11-2004 18:14:38
JC,
Better check her wind next.
Allan
