Transmission problem on IH 384
jeffw47
08-12-2004 06:14:33
I have a IH 384 tractor that when I put the gear in netural the tractor goes in reverse. If I move the gear shifter into any other gear, the tractor lugs and will die unless I push the clutch in. The PTO and hi-lo range works fine. It runs fine when I put the gear shift in netural, except I go backwards. This happened while I was backing up and then shifted into 2nd. Thanks for any help you might could provide.
Allan in NE
08-12-2004 09:05:12
 Re: Transmission problem on IH 384 in reply to jeffw47, 08-12-2004 06:14:33
Jeff,
You've got a shift rail out of time with the other rails.
Allan
Jeffw47
08-12-2004 09:34:59
 Re: Transmission problem on IH 384 in reply to Allan in NE, 08-12-2004 09:05:12
Thanks Allan for the reply. Can I reach that rail from the top where the shifter is?
jeffw47
08-13-2004 08:37:01
 Re: Transmission problem on IH 384 in reply to Jeffw47, 08-12-2004 09:34:59
Allan,
Thanks for all your help. Got the shifter out last night and aligned the rails. Took the shifter to a welder to have the end increased, becuase it looked worn. Thanks again for your help.
Jeff
Allan in NE
08-12-2004 16:04:43
Jeff,
Yes, depending on your configuration, you can usually pull the shifter, then, get in there and line up the gate with a big pry-bar or large screwdriver.
Sorry, I've never owned one of the tractors like you have, but I have worked on thousands of trannys.
Allan
