Order Farmall Cub Parts Online
cracked lifter bore in a CUB block
Larry Mustang
08-14-2004 05:31:04
lifter bore is cracked on two sides of the bore
Cab it be fixed or does it need to be fixed?
john *.?-!.* cub owner
08-14-2004 06:11:55
 Re: cracked lifter bore in a CUB block in reply to Larry Mustang, 08-14-2004 05:31:04
I've never heard of a crack in one of the bores for the valve lifters, but I would thank that as long as the crack doesn't go any further it whouldn't hurt anything. If it's where you can get to it you might try drilling a small hole at each end to stop it from going farther. Are you sure it's a crack and not a mold mark?
