Gasketmaker on hydraulic pump
farmallsc
08-14-2004 17:44:08
would it be possible to use gasketmaker on my hydraulic pump? could it withstand the pressure? i also have to use it on teh seal on the Hydraulic ram on my fast hitch (1951 super C)
CNKS
08-14-2004 17:51:50
 Re: Gasketmaker on hydraulic pump in reply to farmallsc, 08-14-2004 17:44:08
NO -- too much chance of getting it in the system. The gaskets for those parts are cheap. Either use the gasket and no sealer, or a thin coat of copper coat on the gasket.
farmallsc
08-14-2004 17:55:11
 Re: Gasketmaker on hydraulic pump in reply to CNKS, 08-14-2004 17:51:50
what are the gaskets made of, im far away from the parts place
CNKS
08-14-2004 17:59:30
 Re: Gasketmaker on hydraulic pump in reply to farmallsc, 08-14-2004 17:55:11
They are a thin paper type material, some people make their own, but there are many types of gasket material, I would much rather buy them.
farmallsc
08-14-2004 18:05:16
 Re: Gasketmaker on hydraulic pump in reply to CNKS, 08-14-2004 17:59:30
so i could make them out of Cork gasket material?
riverbend
08-14-2004 21:42:17
 Re: Gasketmaker on hydraulic pump in reply to farmallsc, 08-14-2004 18:05:16
The pressure is too high for cork. Try thin paper gasket material, about twice as thick as a sheet of paper. All your surfaces surfaces have to be quite flat. I'd try mail order or ordering on-line to get an IH gasket.
CNKS
08-14-2004 18:15:57
Definitely do NOT use cork. Cork is for valve covers, and possibly oil pans. If you are not in a hurry, order your gaskets from cngco.com, a Case-IH dealer.
