606 numbers
Johann
08-14-2004 18:32:32
Found a metal plate riveted to the right side of my 606 about by the clutch housing. The number 6455 S X Y FF is on it. Can anyone tell me what this means? Also, the backhoe controls have Wagner 8120006 cast on them. Is this enough to assume that I have a Wagner backhoe, and if so what model? Thanks.
sammy the RED
08-14-2004 19:54:59
 Re: 606 numbers in reply to Johann, 08-14-2004 18:32:32
The serial number says you have a 1965 year model.
CNKS
08-14-2004 18:42:46
Don't ask me to explain all this. S is TA with provision for 540 rpm pto, X is high-speed low and reverse attachment, Y is Hydra-touch low and reverse attachment with 12 gpm pump, FF is hydraulic power supply with 4.5 gpm pump. Can't answer the backhoe question.
