valve spring removal
DEK
08-15-2004 04:27:28
I torn down my BN and the valve springs have me stumped. I"d like to get them out so I can mic them. What step am I missing?
Thanks
Gene
08-15-2004 08:20:41
 Re: valve spring removal in reply to DEK, 08-15-2004 04:27:28
You need a valve spring compressor. There are several types or styles available at the auto/tractor parts stores. They are not expensive. Just purchase a good quality one and one that is adjustable.
Basically, you slip one end of the compressor under the spring or place on the valve head and the other end on the top of the spring, compress the spring. Rap the retainer/rotor with a mallet to release the keepers. Remove the keepers, slowly release the spring compressor.
Not much of a job. Be sure to wear safety glasses. If the compressor slips - parts fly.
dek
08-15-2004 17:23:49
 Re: valve spring removal in reply to Gene, 08-15-2004 08:20:41
thanks Gene. I missed the little clip on the valve stem when I had it compressed. Got them out.
john *.?-!.* cub owner
08-15-2004 20:03:40
 Re: valve spring removal in reply to dek, 08-15-2004 17:23:49
When putting them back put a littl dab of grease on the valve stem so they will stick to it while you release the spring.
