43 M
Mike(IL)
08-15-2004 16:35:38
I was cleaning up my M after taking the radiator off for repair and I noticed on the virtical steering shaft" upper bolster pivot shaft" there is a keyway down towards the bolster that faces the rear of the tractor. what is that used for and does it have anything to do with the rectangular insert in the grill?
also, it has loader and live hydralics but this pump leaks. is it possible to put a new pump in the belly and run it off of the shaft the old belly pump did? i know it will not be live any more but just a thought.
it has a wide front end and i notice the bolster shaft will raise about 1 inch when i turn to the right ( i think it was) and will drop back down when turned the other way. could that just be the upper bolster bushing is worn?
thanks for your thoughts
David B
08-15-2004 18:53:29
 Re: 43 M in reply to Mike(IL), 08-15-2004 16:35:38
I believe the keyway is for the old style cultivators that steered, also for lining up steering. However, I believe it should face the front.
The movement: could the steering gear in top of the bolster be in the wrong spot?
Nebraska Cowman
08-15-2004 17:17:37
consider driving a hydraulic pump off the front of the engine for live power. Why don't you want to fix the live pump you have?
Mike(IL)
08-15-2004 18:48:45
 Re: 43 M in reply to Nebraska Cowman, 08-15-2004 17:17:37
That is what i have now is a M & W pump off of the dist drive. i will have to get a speedi sleave i guess. it has a worn shaft that is making it leak i have put new seals in it. from what i have read i was thinking of the cam gear not being very strong. that is why i was thinking of an alternative pump.
thanks Mike
