560 hyd pressure relief
fredmich
08-15-2004 18:33:33
Help, replaced the hyd pump and now have lots of hydraulic power but it seems like it is always working! It labors the engine unless you move the hyd lever and the rpm"s increase. You also have to shut the tractor off to disconnect the remotes. Any ideas would be appreciated. Thanks
Joe Evans
08-15-2004 20:20:03
 Re: 560 hyd pressure relief in reply to fredmich, 08-15-2004 18:33:33
There are four things that can cause the high pressure condition you describe. For more information check this out:
