Positive or Negitive Ground Super WD-9
fishinmex
08-15-2004 21:01:00
I have a 1954 Super WD-9 is it positive or negitive ground? I would like to have it negitive ground with an altanator. Anyone see a problem with this?
Bob M
08-16-2004 05:14:35
 Re: Positive or Negitive Ground Super WD-9 in reply to fishinmex, 08-15-2004 21:01:00
Your SWD-9 electrics would have been shipped positive ground from the factory. However it'll work fine converted to negative ground. Just swap the leads at the ammeter - otherwise the ammeter read "backward" after you convert to negative ground.
fishinmex
08-16-2004 19:37:44
 Re: Positive or Negitive Ground Super WD-9 in reply to Bob M, 08-16-2004 05:14:35
Thanks for the info
CNKS
08-16-2004 18:38:13
Except if the regulator says "positive ground" on it, it will not last as long. Something about the two sets of points being made of different materials. This applies to 6 volt systems, I suppose the 12 volt WD9 would be the same, but not sure.
