Super H mystery
gauger
08-16-2004 10:17:00
In rebuilding a C164 engine I've come across some letters stamped into the top deck of the block. There is the letter "C" next to each bore (side opposite the camshaft) and the letter "A" near the flywheel end. Whaddaya think?
john *.?-!.* cub owner
08-16-2004 10:50:04
 Re: Super H mystery in reply to gauger, 08-16-2004 10:17:00
If you still have the original pistons, they are stamped the same. The equipment that was in use for boring the blocks and machining the pistons at the point in time they were made would give very slight variations, so the bores and pistons were measured and matched with the letteres indicationg the size.
