water pump packing for H
Gary Hunter
08-16-2004 11:09:20
Where can I find A Packing For my 51 H water pump thanks for the help!
Dave S.
08-16-2004 19:22:06
 Re: water pump packing for H in reply to Gary Hunter, 08-16-2004 11:09:20
IH calls it a gasket, the part# is 45925DA. Case/IH had it in stock and I picked up two of them but havent installed them yet. They cost $2.38 EA
Gary Hunter
08-17-2004 06:36:51
 Re: water pump packing for H in reply to Dave S., 08-16-2004 19:22:06
Thanks for the help fellows i've got four packings coming thanks again.
CNKS
08-16-2004 19:30:51
If you are removing the old packing, 3 or possibly 4 is more like it. Be sure to stagger the openings.
CNKS
08-16-2004 17:47:39
I have had trouble with the current Case-IH packing -- impossible to stop small leaks, even with a new water pump. Currently I am using NAPA's version of the string in the post below. It is better, but still drips some.
Tommy D6-8U
08-16-2004 14:34:10
Gary,
I don't have a IH dealer near me so I have tried something else I hope will work. I went to Lowes building supply and bought some teflon valve packing about 1/8" to 3/32" in diameter (its in the plumbing section). I am restoring a 1940 H and I hope this will work. I think you can still get it from IH if you have a dealer near you.
Tommy
Dave_Id
08-16-2004 11:43:19
Case/IH Dealer
