disk for H
ernz
08-17-2004 17:12:06
what size of disk was used with an H. i have an opportunity at a couple of old disks, non hydraulic, and was wanting to know what it could handle. they are an 8' and 10' tandems.
Dr.EVIL
08-18-2004 09:27:36
 Re: disk for H in reply to ernz, 08-17-2004 17:12:06
10 ft was common behind an M unless it was souped up a little, then maybe an 11 or 12 ft depending on blade spacing. typical for H's were 7 ft, so You should be able to pull the 8, just probably a gear slower than would be optimal. In order for discs to work well You have to pull them fairly fast, 4 to 4-1/2 mph minimum. (third gear) Faster is better because they throw dirt better and leave a smoother surface. It IS possible to pull them too fast and cause ridging with the rear gangs, but You sure won't have that problem.
Chris Brown
08-17-2004 19:48:43
I pull a #37 IH wheel disk with the H,it is 9.5 feet and it works it pretty hard but it pulls it. I have been told that is to much for it. I would say an 8 footer would be fine.
ernz
08-18-2004 03:18:26
 Re: disk for H in reply to Chris Brown, 08-17-2004 19:48:43
thanks for the replies, i think i will stick with the 8'.
riverbend
08-17-2004 17:46:46
If you have high compression pistons in your H, the 8' would be plenty.
