300 runs on 14, rarely on 1,2,34. Help
Bill in Orono,M
08-17-2004 18:26:14
Hello,
Well, she'll start, and run (no power) on just 1&4. I checked and cleaned the 2&3 plugs (smelled gasoline), wire tested ok. What might the weak link be? Why just 2&3??
Thanks
jasc in pa
08-17-2004 21:25:43
 Re: 300 runs on 14, rarely on 1,2,34. Help in reply to Bill in Orono,MN, 08-17-2004 18:26:14
if your firing order is right and getting spark chech compression you might have blown a head gasket that is common problem when 2&3 wont fire right
James H in Tx
08-17-2004 21:20:07
You might try doing a compression test.
Hermit
08-17-2004 19:32:27
You might want to check for carbon tracks in the distributor cap. It may have a crack in it.
CNKS
08-17-2004 18:37:38
Be sure the plugs, wires, and distributer cap are ok. Then make sure the distributer cam, etc are not worn and/or loose. The points might open on 1 and 4, but not on 2 and 3. Then check the valve clearance, although it would have to be way off for that problem to occur. Beyond that, I don't know.
Bill in Orono,MN
08-17-2004 18:44:25
 Re: 300 runs on 14, rarely on 1,2,34. Help in reply to CNKS, 08-17-2004 18:37:38
I will check the points, maybe I have them too tight.
CNKS
08-17-2004 18:58:07
 Re: 300 runs on 14, rarely on 1,2,34. Help in reply to Bill in Orono,MN, 08-17-2004 18:44:25
0.020 -- should be the same on all four sides of the cam.
K.B.-826
08-17-2004 18:32:55
Try swapping plugs and wires around, see if the miss follows. Other than that, corrosion in the distributor cap terminals, or stuck valves? Sure you've got the firing order right?
Bill in Orono,MN
08-17-2004 18:41:37
 Re: 300 runs on 14, rarely on 1,2,34. Help in reply to K.B.-826, 08-17-2004 18:32:55
I'll try the moving the wires and plugs and see if I can eliminate any of them.
parts man
08-17-2004 19:41:20
 Re: 300 runs on 14, rarely on 1,2,34. Help in reply to Bill in Orono,MN, 08-17-2004 18:41:37
Make sure you don"t have #s 2 and 3 switched.
