clutch adjustment on C Farmall
wildman
08-18-2004 18:05:26
Need to know clutch adjustment on C Farmall just got running started to drive mashed clutch gears grind. Tractor set up several years.Any help will be great Thanks in advance for any help. Wildman
CNKS
08-18-2004 18:11:56
 Re: clutch adjustment on C Farmall in reply to wildman, 08-18-2004 18:05:26
Factory spec is 1 7/16 inches from the pedal to transmission cover. Gears will always grind if you don't wait for them to stop turning after you push in the clutch. This can be minimized if they are shifted at idle. There should be only minimal grinding when shifting with the tractor moving, unless you are shifting from 4th to a lower gear. The gears are not syncronized.
Randy in NE
08-19-2004 04:14:17
 Re: clutch adjustment on C Farmall in reply to CNKS, 08-18-2004 18:11:56
You can also slow the spinning gears down a little faster by moving the gear shift lever all the way to the right and then pushing it forward. I'm not sure what is happening in there but it definitely helps a lot.
