Crank case oil for C Farmall
wildman
08-19-2004 05:46:08
What oil should I use in C Farmall engine. Thanks for any help
sammy the RED
08-20-2004 12:08:34
 Re: Crank case oil for C Farmall in reply to wildman, 08-19-2004 05:46:08
30 wt in summer.
10w30 in winter.
captaink
08-19-2004 07:23:59
As rustyfarmall indicates, oil like you would use in any other vehicle. I recommend for temps constantly below 32 degrees 5W-20. If it never gets below zero or higher than 70 I suggest 10W-30, and if it is constantly above 50, then go with 15-40. My nickel’s worth…
rustyfarmall
08-19-2004 06:16:47
You can use any good brand of multi-weight oil. Whatever you use in your car, truck, or other machinery should do just fine.
