350 hydraulic pump leaks into dist drive
Newman Red
08-19-2004 20:26:28
My 350 Farmall gas leaks hydraulic oil into the distrubter drive housing. Can this be resealed from the outside or does the pump have to be taken off and apart?
LJ
08-20-2004 04:26:29
 Re: 350 hydraulic pump leaks into dist drive in reply to Newman Red, 08-19-2004 20:26:28
YOur seal in your pump has gone bad. You will need to remove it to fix it.
